Aller au contenu principal
Disassembling Onkyo TX-800 Face plate
Ce dont vous avez besoin
  1. Disassembling Onkyo TX-800 Face plate, Disassembling Onkyo TX-800 Top case: étape 1, image 1 de 3 Disassembling Onkyo TX-800 Face plate, Disassembling Onkyo TX-800 Top case: étape 1, image 2 de 3 Disassembling Onkyo TX-800 Face plate, Disassembling Onkyo TX-800 Top case: étape 1, image 3 de 3
    • Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
  2. Disassembling Onkyo TX-800 Face plate: étape 2, image 1 de 2 Disassembling Onkyo TX-800 Face plate: étape 2, image 2 de 2
    • Remove the top screw on the back panel.
  3. Disassembling Onkyo TX-800 Face plate: étape 3, image 1 de 2 Disassembling Onkyo TX-800 Face plate: étape 3, image 2 de 2
    • Slide off the case to expose the internal components of the receiver.
  4. Disassembling Onkyo TX-800 Face plate, Face plate: étape 4, image 1 de 3 Disassembling Onkyo TX-800 Face plate, Face plate: étape 4, image 2 de 3 Disassembling Onkyo TX-800 Face plate, Face plate: étape 4, image 3 de 3
    • Unscrew the three screws on top of the face plate.
  5. Disassembling Onkyo TX-800 Face plate: étape 5, image 1 de 2 Disassembling Onkyo TX-800 Face plate: étape 5, image 2 de 2
    • Unscrew the one screw on the bottom of the front panel.
  6. Disassembling Onkyo TX-800 Face plate: étape 6, image 1 de 3 Disassembling Onkyo TX-800 Face plate: étape 6, image 2 de 3 Disassembling Onkyo TX-800 Face plate: étape 6, image 3 de 3
    • Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force.
2 autres ont terminé cette réparation.
Ryan
Membre depuis le 04/13/10
108 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 27-92, Amido Spring 2010 Membre de l'équipe Cal Poly, Team 27-92, Amido Spring 2010
CPSU-AMIDO-S10S27G92
4 membres
7 tutoriels rédigés
2 commentaires
I would like to remove Front Face plate of my Onkyo TX-SR875 AV Receiver. Please guide me how can I open it?
Ashish Solanki - Réponse
My Onkyo DX-C370 was “working fine..” until the belts started breaking. Following your disassembly and re-assembly guide, I replaced 3-belts using medium tension O-rings. Drawer opens/closes…, BUT carousel “studders” as it enters the pick-up unit, which does not engage with disk on “PLAY” button depression. I have Service Manual from online source.., and would like to follow “ERROR MESSAGE displays in “Heat-Running Mode” BUTY…, I do not know which panel button corresponds to the “DOWN BUTTON”.., Can You advise on how to get it spinning and playing CDs again..?
Much Thanks, Dom. Mendola, Ph.D. UCSD, Scripps Institution of Oceanography, Retired…
Dominick Mendola - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 19
Total : 3,787
