Introduction
Since this is step one, you will just need to start with your camera.
Pièces
Aucune pièce nécessaire.
Remove the battery and memory card from the device.
  • Remove the battery and memory card from the device.
Ajouter un commentaire
Remove 4 screws from the right side of the camera.
  • Remove 4 screws from the right side of the camera.
    • There are two 3.4mm screws at the top.
    • There are two 2.2mm screws at the bottom.
Remove the single 3.4mm screw on the left side of the camera.
  • Remove the single 3.4mm screw on the left side of the camera.
Remove 5 screws from the base of the camera.
  • Remove 5 screws from the base of the camera.
    • There are two 2.2mm screws next to the battery compartment.
    • There are three 4mm screws around the tripod mount.
Slowly slide the back cover away from the device
  • Slowly slide the back cover away from the device
    • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
Detach both ribbon cables using a spudger. Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
  • Detach both ribbon cables using a spudger.
    • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
Remove the back casing from the camera.
  • Remove the back casing from the camera.
4 autre(s) ont terminé cette réparation.
Ben Canfield
Membre depuis le 10/10/2010
391 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 9-21, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 9-21, Regan Fall 2010
CPSU-REGAN-F10S9G21
4 membres
7 tutoriels rédigés
That is not a disassembly! All is shows is taking the back of the camera off. How about showing how to disassembly the camera down to its individual components and make repairs, like getting the lens to extend of fixing a sticking shutter.
JR Tan - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 17
Total : 5,917
