Aller au contenu principal
Polaroid a520 LCD Screen Replacement
Ce dont vous avez besoin
  1. Polaroid a520 LCD Screen Replacement, Battery: étape 1, image 1 de 2 Polaroid a520 LCD Screen Replacement, Battery: étape 1, image 2 de 2
    • Place your thumb on the battery cover and push left towards the arrow.
    • The cover will release and pop open.
  2. Polaroid a520 LCD Screen Replacement: étape 2, image 1 de 1
    • Remove the batteries from the camera.
  3. Polaroid a520 LCD Screen Replacement, Casing: étape 3, image 1 de 1
    • Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
    • This will release the front and back casings.
  4. Polaroid a520 LCD Screen Replacement: étape 4, image 1 de 1
    • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Repeat this step for the back casing.
  5. Polaroid a520 LCD Screen Replacement, LCD Screen: étape 5, image 1 de 1
    • Under the screen, locate the black plastic strip that sits above the white plastic strip.
  6. Polaroid a520 LCD Screen Replacement: étape 6, image 1 de 1
    • Pull both sides of the black piece upward-about a mm.
    • The black plastic piece is not meant to come all the way off, just enough to release the screen.
    • Once the piece is lifted carefully slide the screen out of the slot.
Dani
Membre depuis le 06/24/10
21 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 3-3, Johann Summer 2010 Membre de l'équipe Cal Poly, Team 3-3, Johann Summer 2010
CPSU-JOHANN-R10S3G3
2 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 1,670
