Pièces
Aucune pièce nécessaire.
Locate the battery cover on the bottom of the camera.
  • Locate the battery cover on the bottom of the camera.
Ajouter un commentaire
Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
  • Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
Remove the batteries from the camera.
  • Remove the batteries from the camera.
Unscrew and remove four (3mm) screws on the right side of the camera. This will release the front and back casings.
  • Unscrew and remove four (3mm) screws on the right side of the camera. This will release the front and back casings.
Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
  • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
  • Repeat this step for the back casing.
Locate the black plastic strip under the screen above the white plastic strip.
  • Locate the black plastic strip under the screen above the white plastic strip.
Pull up both sides of the black piece up about a mm.
  • Pull up both sides of the black piece up about a mm.
  • The black plastic piece is not meant to come all the way off, just enough to release the screen.
  • Once the piece is lifted carefully slide the screen out of the slot.
Unscrew and remove the four (6 mm) screws on the inside casing.
  • Unscrew and remove the four (6 mm) screws on the inside casing.
Pull the inner casing off of the camera.
  • Pull the inner casing off of the camera.
Unscrew and remove the four (4mm) screws from the logic board.
  • Unscrew and remove the four (4mm) screws from the logic board.
Use a spudger to pry up all four sides of the logic board and slide it out of the camera.
  • Use a spudger to pry up all four sides of the logic board and slide it out of the camera.
Unscrew and remove the two (5mm) screws from the logic board to the far left.
  • Unscrew and remove the two (5mm) screws from the logic board to the far left.
Locate the black plastic piece behind the lens.
  • Locate the black plastic piece behind the lens.
Similar to the LCD screen, pull the black piece up about a mm and it will release the lens.
  • Similar to the LCD screen, pull the black piece up about a mm and it will release the lens.
  • The piece will not come all the way off; only enough to release the lens.
  • Once the black piece is lifted slide the ribbon out to release the lens.
Dani
Membre depuis le 24/06/2010
21 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 3-3, Johann Summer 2010 Membre de l'équipe Cal Poly, Team 3-3, Johann Summer 2010
CPSU-JOHANN-R10S3G3
2 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 847
