Introduction
This guide will instruct you to take the left cover off of the camcorder.
Remove the 6-7.9mm ph#0 screws on the back and bottom. Remove the one 3.8mm ph#0 screw on the bottom.
  • Remove the 6-7.9mm ph#0 screws on the back and bottom.
  • Remove the one 3.8mm ph#0 screw on the bottom.
  • Remove the two 7.5mm ph#0 screws on the back and bottom.
Ajouter un commentaire
Remove 5.8mm ph#1 screw from the side button panel. Slide the viewfinder all the way to the right and remove the 7.9mm ph#0 screw.
  • Remove 5.8mm ph#1 screw from the side button panel.
  • Slide the viewfinder all the way to the right and remove the 7.9mm ph#0 screw.
Pry along the seam on the top side near the buttons with a spudger. Pry along the seam on the top side near the buttons with a spudger.
  • Pry along the seam on the top side near the buttons with a spudger.
Pull the left panel away from the rest of the camcorder. Unplug the red speaker cable located at the rear of the device.
  • Pull the left panel away from the rest of the camcorder.
  • Unplug the red speaker cable located at the rear of the device.
  • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
Ashley Katchadourian
Membre depuis le 20/01/2011
112 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 5-20, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 583
