Aller au contenu principal
Disassembling the Samsung Laptop Ultrabook NP530U3B
Ce dont vous avez besoin
  1. Disassembling the Samsung Laptop Ultrabook NP530U3B, Disassembling the Samsung Laptop Ultrabook NP530U3B: étape 1, image 1 de 1
    • Remove the 8 small screws.
  2. Disassembling the Samsung Laptop Ultrabook NP530U3B: étape 2, image 1 de 2 Disassembling the Samsung Laptop Ultrabook NP530U3B: étape 2, image 2 de 2
    • Remove the other 6 screws.
    • Remove the hard disk and the RAM slots.
  3. Disassembling the Samsung Laptop Ultrabook NP530U3B: étape 3, image 1 de 1
    • This is the hard disk - Hitachi 500 GB
  4. Disassembling the Samsung Laptop Ultrabook NP530U3B: étape 4, image 1 de 1
    • Ensure that the hard disk has been removed. Carefully detach the bottom cover.
  5. Disassembling the Samsung Laptop Ultrabook NP530U3B: étape 5, image 1 de 1
    • Once the bottom cover is removed, your device should look like this.
  6. Disassembling the Samsung Laptop Ultrabook NP530U3B: étape 6, image 1 de 1
    • Remove the 4 screws to detach the battery.
    • Remove all of the sticky tape.
    • Carefully disconnect the small power connector by using a tool to push the connector out through the small gap in the middle of the connector.
    • The connector won't come out all the way, because the battery pack is in its way.
  7. Disassembling the Samsung Laptop Ultrabook NP530U3B: étape 7, image 1 de 2 Disassembling the Samsung Laptop Ultrabook NP530U3B: étape 7, image 2 de 2
    • This is the Samsung 7.4V 45Wh battery.
    • Ensure that the battery is removed before continuing.
  8. Disassembling the Samsung Laptop Ultrabook NP530U3B: étape 8, image 1 de 1
    • When the battery is removed, this is how it will look.
  9. Disassembling the Samsung Laptop Ultrabook NP530U3B: étape 9, image 1 de 1
    • Remove the processor fan.
    • There are 2 screws holding it in place. Loosen and remove them.
  10. Disassembling the Samsung Laptop Ultrabook NP530U3B: étape 10, image 1 de 1
    • This is the processor fan.
  11. Disassembling the Samsung Laptop Ultrabook NP530U3B: étape 11, image 1 de 1
    • Remove the processor heat sink.
    • 3 screws hold this part in place. Loosen and remove them.
  12. Disassembling the Samsung Laptop Ultrabook NP530U3B: étape 12, image 1 de 1
    • Disconnect the antenna cables from the WiFi card.
    • Remove the screw.
    • Be sure to match the colors when reattaching the cables.
  13. Disassembling the Samsung Laptop Ultrabook NP530U3B: étape 13, image 1 de 1
    • Remove the screw.
    • Lift the latch upwards to loosen the cable.
  14. Disassembling the Samsung Laptop Ultrabook NP530U3B: étape 14, image 1 de 1
    • Remove the screw.
  15. Disassembling the Samsung Laptop Ultrabook NP530U3B: étape 15, image 1 de 1
    • Remove the screw.
  16. Disassembling the Samsung Laptop Ultrabook NP530U3B: étape 16, image 1 de 1
    • To remove the Motherboard, carefully disconnect the cables.
  17. Disassembling the Samsung Laptop Ultrabook NP530U3B: étape 17, image 1 de 2 Disassembling the Samsung Laptop Ultrabook NP530U3B: étape 17, image 2 de 2
    • This is the Motherboard - there is a front and rear view.
34 autres ont terminé cette réparation.
Jose Gustavo Abreu Murta
Membre depuis le 07/06/10
4 588 Réputation
9 tutoriels rédigés
30 commentaires
Hello,
Do you know where can i reset the Bios CMOS in that motherboard?
I think there are people who wants to know becose system upgrade is leading to bios ACPI Error.
Thanks for your help
Luis Orland - Réponse
No, I do not know where is a reset pin of BIOS.
Try to disconnect NVRAM battery.
Wait 15 minutes and reconnect again.
Jose Gustavo Abreu Murta - Réponse
To reset BIOS this NP530U3, only disconnect all power supply (MAIN battery, CMOS battery and power source). And hold press POWER button for 1 min.
warmdk - Réponse
I try it but don't work, do you know another way to do this
manhique -
Hello,
I have seen many screens with model number LTN140AT21-XXX for this laptop. My laptop NP530u4b has a screen LTN140AT21-802. I would like to know if I can use a LTN140AT21-002 screen, or if only is good a screen with number LTN140AT21-8.
thanks for your help.
alex - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 56
Total : 52,867
