Aller au contenu principal
Disassembling Sony Clie PEG-SL10
Ce dont vous avez besoin
  1. Disassembling Sony Clie PEG-SL10, Disassembling Sony Clie PEG-SL10: étape 1, image 1 de 1
    • Start by holding your Sony Clie PEG-SL10 face-up in your hand.
  2. Disassembling Sony Clie PEG-SL10: étape 2, image 1 de 1
    • Turn over your Sony Clie and unlock the cover slide lock.
  3. Disassembling Sony Clie PEG-SL10: étape 3, image 1 de 1
    • After unlocking the cover slide lock, remove the cover and set aside.
  4. Disassembling Sony Clie PEG-SL10: étape 4, image 1 de 1
    • Turn your Sony Clie face-up.
    • Using a Phillips #0 screwdriver, remove the six case screws on the sides and bottom of the device.
  5. Disassembling Sony Clie PEG-SL10: étape 5, image 1 de 1
    • Remove the front case by gently lifting away from the device.
  6. Disassembling Sony Clie PEG-SL10: étape 6, image 1 de 1
    • Turn the Sony Clie face down and open the back case by prying open the left side of the device.
    • It will open like a book connected by hinges on the right side.
  7. Disassembling Sony Clie PEG-SL10: étape 7, image 1 de 1
    • Gently pry off the right side off the back panel and set it aside, leaving room for the scroll wheel at the upper right corner.
  8. Disassembling Sony Clie PEG-SL10: étape 8, image 1 de 1
    • Using a Phillips #0 screwdriver, remove the two screws holding the scroll wheel in place.
  9. Disassembling Sony Clie PEG-SL10: étape 9, image 1 de 1
    • Pull out both sides of the clip to remove the scroll wheel power cable from the device.
  10. Disassembling Sony Clie PEG-SL10: étape 10, image 1 de 1
    • Using a Phillips #0 screwdriver, unscrew the two screws towards the bottom sides of the Sony Clie to remove the battery harness.
  11. Disassembling Sony Clie PEG-SL10: étape 11, image 1 de 1
    • Pull the power cable from the socket located above the upper right side of the battery harness.
  12. Disassembling Sony Clie PEG-SL10: étape 12, image 1 de 1
    • Gently pull out the clips to remove the bottom power cables from the motherboard after removing the battery harness.
  13. Disassembling Sony Clie PEG-SL10: étape 13, image 1 de 1
    • Rotate the motherboard 180 degrees so that it is upside down facing toward you to expose the power cables on the other side.
  14. Disassembling Sony Clie PEG-SL10: étape 14, image 1 de 1
    • Gently pull out the clips to remove the top power cables from the motherboard.
Pièces jointes
Steve
Membre depuis le 10/18/11
9 Réputation
1 tutoriel rédigé
Équipe
James Madison, Team 1-4, Allen Fall 2011 Membre de l'équipe James Madison, Team 1-4, Allen Fall 2011
JMU-ALLEN-F11S1G4
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 14
Total : 1,706
