Pièces
Aucune pièce nécessaire.
Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
  • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
Ajouter un commentaire
Slide the back cover off by pushing it to the left, away from the side that held the screws.
  • Slide the back cover off by pushing it to the left, away from the side that held the screws.
  • Remove the cover.
This is what the device should look like once the back cover panel has been removed.
  • This is what the device should look like once the back cover panel has been removed.
Remove the stylus from the device.
  • Remove the stylus from the device.
Using the Phillips screwdriver remove the 1.4 mm screw from the top panel. Using the same screwdriver, remove the 1.4 mm screw from the back of the device. Pry apart off the top panel of the device.
  • Using the Phillips screwdriver remove the 1.4 mm screw from the top panel.
  • Using the same screwdriver, remove the 1.4 mm screw from the back of the device.
  • Pry apart off the top panel of the device.
Using a Phillips head screwdriver, remove the two 1.4 mm screws from the bottom panel of the device. Using the same screwdriver, remove the 1.4 mm screw that is located on the back of the device.
  • Using a Phillips head screwdriver, remove the two 1.4 mm screws from the bottom panel of the device.
  • Using the same screwdriver, remove the 1.4 mm screw that is located on the back of the device.
Pull the panel away from the device. You may have to use the flat end of the spudger to remove the side portion of the panel because it will be glued in place. Pull the panel away from the device. You may have to use the flat end of the spudger to remove the side portion of the panel because it will be glued in place.
  • Pull the panel away from the device. You may have to use the flat end of the spudger to remove the side portion of the panel because it will be glued in place.
Zachary Jeffers
Membre depuis le 13/10/2014
409 Réputation
4 tutoriels rédigés
Équipe
Clemson, Team 1-4, Benson Fall 2014 Membre de l'équipe Clemson, Team 1-4, Benson Fall 2014
CLEM-BENSON-F14S1G4
4 membres
11 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 99
