Introduction
Use this guide to open up the outer case of your Visioneer OneTouch 7400 USB, which will allow you to access the device's internal hardware.
Pièces
Aucune pièce nécessaire.
On the bottom of the scanner, remove the screw at the top left side.
  • On the bottom of the scanner, remove the screw at the top left side.
Ajouter un commentaire
Remove the rubber foot pad opposite the screw hole to expose a second screw hole. Remove the screw beneath the foot-pad.
  • Remove the rubber foot pad opposite the screw hole to expose a second screw hole.
  • Remove the screw beneath the foot-pad.
Rotate the scanner so the screw hole is located on the top left hand side. Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up. Gently pry the two casements apart beginning above the screw hole and working your way around.
  • Rotate the scanner so the screw hole is located on the top left hand side.
  • Place the plastic opening tool between the top casement and bottom casement of scanner with the hook facing up.
  • Gently pry the two casements apart beginning above the screw hole and working your way around.
  • Note that the top and bottom casings are held together by a series of 6 tabs. There is one tab on each of the long sides of the scanner approximately 6 inches in from the corners. There are two tabs on each of the short sides of the scanner approximately 2.3 inches in from the corners. Use the spudger to unhook the tab from the top casement.
Separate the two casement pieces.
  • Separate the two casement pieces.
Jena
Membre depuis le 18/10/2013
608 Réputation
6 tutoriels rédigés
Équipe
University of Maine, Team 1-13, Diaz Fall 2013 Membre de l'équipe University of Maine, Team 1-13, Diaz Fall 2013
UMAINE-DIAZ-F13S1G13
3 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 154
