Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre Oregon Scientific Ultra Thin Weather Station, utilisez notre manuel de réparation.
Weather Box, front side
  • Weather Box, front side
Ajouter un commentaire
Rear side Rear side Rear side
  • Rear side
External front side is a a plastic screen glued to the equipment. To disassembly it, insert a knife to cut the glue. It is soft glue, silicone, probably.
  • External front side is a a plastic screen glued to the equipment. To disassembly it, insert a knife to cut the glue. It is soft glue, silicone, probably.
  • Be carefull to not damage external plastic with knife
After plastic screen removed, it can see the screws. With a small screw driver, take them off. There are eight screws. With a small screw driver, take them off. There are eight screws.
  • After plastic screen removed, it can see the screws.
  • With a small screw driver, take them off. There are eight screws.
After screws removed, it is posible disassembly equipment by inserting a flat screw in the sides. It is strong enough to resist some efforts. Be carefull anyway.
  • After screws removed, it is posible disassembly equipment by inserting a flat screw in the sides. It is strong enough to resist some efforts. Be carefull anyway.
Internal view Internal view Internal view
  • Internal view
Andres
Membre depuis le 14/11/2013
110 Réputation
1 tutoriel rédigé
I see that your weather box LCD screen in your pictures is not working. I have just fixed the same issue on my BAR800 weather box; if you have not fixed that issue yet, I can tell you how to do that.
Fulvio Galiani - Réponse
how do you fix that i have busted screen on a bar 800 and need directions
Filip cauwel -
Hi Fulvio, I have a BAR800 and the display has some missing segments - please can you let me know how to fix it.
Thanks
Vic -
Hi Fulvio, I have the same problem! How did you fix it?
Andrea V -
I lost the the sound on this demo. Does anyone else have the same problem?
Sheila McWilliams - Réponse
I was hoping that Andre could repost this repair. I only show a partial post. This fix is exactly what I need. Thanks, Sheila
Hello, useful repair description. It does not solve the whole but it helps .... My bar 800 was defect. Screen was flashing whole time, like a kind of reset during inilization that never ends up .... So all possible signs in display were shown and after 1 sec all off. This again and again...Thanks to the instructions i disassembled the station. I disoldered the small platine and seems to work ALL again!!! What is then the small platine for?! My suposition is that the small platine could be a barometer, that only is issued for wheater forecast. Now it is showing raining and maybe forever ....
pilaralfageme - Réponse
Can you please repost or add once more your procedure?
Frantisek Suchy -
Voir les statistiques:
Dernières 24 heures : 6
7 derniers jours : 10
30 derniers jours : 28
Total : 1,715
