Aller au contenu principal
Disassembling Yamaha YPG-225 Faceplate
Ce dont vous avez besoin
  1. Disassembling Yamaha YPG-225 Faceplate, Batteries: étape 1, image 1 de 1
    • Turn the keyboard over so that the keys are facing the ground.
  2. Disassembling Yamaha YPG-225 Faceplate: étape 2, image 1 de 1
    • Pop the tabs on the battery casing and remove it from the back plate.
  3. Disassembling Yamaha YPG-225 Faceplate: étape 3, image 1 de 1
    • Locate the six batteries and remove them from the battery cavity.
  4. Disassembling Yamaha YPG-225 Faceplate, Faceplate: étape 4, image 1 de 1
    • Remove the six 10mm screws at the top of the backplate.
  5. Disassembling Yamaha YPG-225 Faceplate: étape 5, image 1 de 1
    • Remove the seven 12mm screws in the middle of the back plate.
  6. Disassembling Yamaha YPG-225 Faceplate: étape 6, image 1 de 1
    • Remove the eight 10mm screws from the side and the bottom of the back plate.
  7. Disassembling Yamaha YPG-225 Faceplate: étape 7, image 1 de 1
    • As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
    • Flip over the keyboard.
  8. Disassembling Yamaha YPG-225 Faceplate: étape 8, image 1 de 2 Disassembling Yamaha YPG-225 Faceplate: étape 8, image 2 de 2
    • Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
    • Be careful when removing the face plate. There are wires attached.
Lonnie Bissmeyer
Membre depuis le 09/16/12
444 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 2-62, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 2-62, Propen Fall 2012
CPSU-PROPEN-F12S2G62
2 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 15
Total : 1,666
