Introduction
Behold the iClicker. This learning device is used in some college classrooms to help make the learning process more interactive. Course instructors can ask multiple choice questions and students can respond by pressing the button that corresponds to the answer they desire.
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre iClicker, utilisez notre manuel de réparation.
Behold the iclicker in all its interactive and educational beauty.
  • Behold the iclicker in all its interactive and educational beauty.
Ajouter un commentaire
Place the device on a flat surface, buttons facing down.
  • Place the device on a flat surface, buttons facing down.
  • Remove the battery cover and the three batteries within.
Remove the two visible screws using a #00 Phillips screwdriver. Oops! Don't forget a hidden third screw beneath the factory label.
  • Remove the two visible screws using a #00 Phillips screwdriver.
  • Oops! Don't forget a hidden third screw beneath the factory label.
  • Peel back the corner of the label to reveal the hidden screw.
  • If you wish to maintain the integrity of the label, a blowdryer may be used to soften the adhesive on the label before removal.
Depending on how much abuse your iclicker has endured, you might be able to separate the front and rear panels of the iclicker with your fingers. For the more resistent iclickers, a spudger may be employed to separate the pieces.
  • Depending on how much abuse your iclicker has endured, you might be able to separate the front and rear panels of the iclicker with your fingers.
  • For the more resistent iclickers, a spudger may be employed to separate the pieces.
Your iclicker is now exposed for all its worth.
  • Your iclicker is now exposed for all its worth.
  • The back panel can be set aisde, as the remaining components are housed in the front panel.
Using a spudger, gently pry the battery connectors from the front panel. Using a spudger, gently pry the battery connectors from the front panel.
  • Using a spudger, gently pry the battery connectors from the front panel.
If your circuit board is stuck in the front panel, use a spudger to lift the circuit board from the front panel.
  • If your circuit board is stuck in the front panel, use a spudger to lift the circuit board from the front panel.
The buttons can be easily removed from the front assembly sans spudger.
  • The buttons can be easily removed from the front assembly sans spudger.
Don't lose the small LED cover sitting precariously in the front panel.
  • Don't lose the small LED cover sitting precariously in the front panel.
Your iclicker is now disassembled.
  • Your iclicker is now disassembled.
What is an iClicker ?
furbies - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 6,537
