Introduction
The bottom of your Roomba can be easily removed by just removing the side brush, unscrewing four screws, and separating the plate from the device.
Pièces
Aucune pièce nécessaire.
Place your Roomba upside-down on a hard surface.
  • Place your Roomba upside-down on a hard surface.
If all you need off is the faceplate, skip all of the screwdriver-based steps, and just remove the dirt bin(step 7) and start from step 11 at the rear.
David Forrest - Réponse
While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
Ajouter un commentaire
Gently pull upwards on the brush to remove it.
  • Gently pull upwards on the brush to remove it.
Rotate the Roomba upside-down so the bottom is facing towards you.
  • Rotate the Roomba upside-down so the bottom is facing towards you.
Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place. Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
Carefully lift the bottom plate.
  • Carefully lift the bottom plate.
  • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
Deborah Newberry
Membre depuis le 23/01/2014
527 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 13-14, Regan Winter 2014 Membre de l'équipe Cal Poly, Team 13-14, Regan Winter 2014
CPSU-REGAN-W14S13G14
4 membres
13 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 320
