Aller au contenu principal
Display Assembly
Ce dont vous avez besoin
    • Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
    • Disconnect the antenna cable.
    • Close the display.
    • Turn the computer upside down with the back of the computer facing you.
  1. Display Assembly, Remove the Screws: étape 2, image 1 de 1
    • From the bottom of the computer, remove the two M2.5 x 8-mm screws labeled "D."
  2. Display Assembly, Remove the Screws: étape 3, image 1 de 2 Display Assembly, Remove the Screws: étape 3, image 2 de 2
    • From the back of the computer, remove the two M2.5 x 8-mm screws labeled "D."
  3. Display Assembly, Removing the Cables: étape 4, image 1 de 1
    • Turn the computer right-side up and open the display.
    • Carefully remove the antenna cable and the display cables from their routing guides.
  4. Display Assembly, Lifting the Display Assembly: étape 5, image 1 de 1
    • NOTICE: Be careful not to damage the display switch when removing the display.
    • Lift the display assembly out of the computer base.
Terrence15
Membre depuis le 12/18/17
79 161 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 986 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 14
Total : 534
