Introduction
Use this guide to replace the controller's motherboard. Completely replacing the board will require de-soldering the existing vibration motors and soldering them to the new board.
Ce dont vous avez besoin
Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
Lift the battery off the motherboard for enough clearance to access the battery connector.
Remove the single 7.2 mm Phillips screw securing the motherboard to the front cover.
Pull both analog stick covers straight up off their joystick posts attached to the motherboard.
42 autres ont terminé cette réparation.
15 commentaires
Do i have to take the vibration motors off?What if i have a replacement motherboard with vibration motors already on,can i just replace it with that one?
P.S.-Pretty new to fixing these remotes so i apologize if my questions may sound stupid.
I'm not sure if anyone replied to your comment, but yes you can just use the new motherboard with the vibration devices already attached. It appears that some of the motherboards do not come with them already. If it doesn't then you would have to solder etc
I have a dual shock 3 and my son accidentally drooled on it and it won't turn or anything, I had it brand new for 3 weeks, what do u think it is? Input board? Motherboard?
