Introduction
This will show you how to remove the outer shell of the Dualshock 4 so you can replace it or get inside the controller.
Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver. Pry the two halves of the shell apart using a plastic opening tool. Be careful, as there will be a ribbon connecting the inner workings of the controller. It will not separate into two parts just by pulling apart the shell.
  • Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
  • Pry the two halves of the shell apart using a plastic opening tool.
  • Be careful, as there will be a ribbon connecting the inner workings of the controller. It will not separate into two parts just by pulling apart the shell.
Ajouter un commentaire
Idées cadeaux pour la Fête des Pères
Mettons nos papas à l’honneur ainsi que nos mentors qui nous ont appris à réparer.
Honorons ceux qui nous ont enseigné à réparer.
Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers. Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers. Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
  • Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
David Seale
Membre depuis le 09/10/2017
337 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S1-G5, Leahy Fall 2017 Membre de l'équipe USF Tampa, Team S1-G5, Leahy Fall 2017
USFT-LEAHY-F17S1G5
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 19
30 derniers jours : 107
Total : 634
