Introduction
Over time, your DualShock 4 controller will probably be dropped, stepped on, or even thrown. The plastic shell helps to protect the internal components of the controller, but eventually, you might find that this protective shell needs to be replaced or re-aligned. This step-by-step process will show you how to fix this problem yourself.
To remove the plastic shell, use the Phillips #00 Screwdriver to remove the four 6.0 mm screws securing the back of the controller.
  • To remove the plastic shell, use the Phillips #00 Screwdriver to remove the four 6.0 mm screws securing the back of the controller.
Ajouter un commentaire
The plastic shell is held in place by little plastic tabs that snap together.
  • The plastic shell is held in place by little plastic tabs that snap together.
  • Wedge the plastic opening tool between the shell and the controller and carefully pry off the plastic.
  • Take your time on this step. You do not want to break any plastic pieces.
Either re-align the old plastic shell, or align a new replacement shell with the controller. The little plastic tabs that snap together should be aligned.
  • Either re-align the old plastic shell, or align a new replacement shell with the controller. The little plastic tabs that snap together should be aligned.
  • Apply pressure on the plastic housing so that it clicks together.
Using the Phillips #00 Screwdriver, replace and tighten the four 6.0 mm screws on the back of the controller.
  • Using the Phillips #00 Screwdriver, replace and tighten the four 6.0 mm screws on the back of the controller.
18 autre(s) ont terminé cette réparation.
Dustin
Membre depuis le 12/03/2014
921 Réputation
7 tutoriels rédigés
Équipe
can you go over the removal of the shell in detail? this barely teaches anything at all
Matt Law - Réponse
Voir les statistiques:
Dernières 24 heures : 15
7 derniers jours : 129
30 derniers jours : 538
Total : 36,669
