Aller au contenu principal
Durofix RV332 Battery LED Replacement
Ce dont vous avez besoin
  1. Durofix RV332 Battery LED Replacement, Battery LED: étape 1, image 1 de 1
    • Remove the six 13 mm case screws with a #0 Phillips screwdriver from the side of the power screwdriver.
  2. Durofix RV332 Battery LED Replacement: étape 2, image 1 de 2 Durofix RV332 Battery LED Replacement: étape 2, image 2 de 2
    • Using a plastic opening tool, separate the case in two to expose the internals of the cordless screwdriver.
  3. Durofix RV332 Battery LED Replacement: étape 3, image 1 de 3 Durofix RV332 Battery LED Replacement: étape 3, image 2 de 3 Durofix RV332 Battery LED Replacement: étape 3, image 3 de 3
    • Remove printed circuit board, LED, battery, and motor assembly from the screwdriver casing.
    • Use a soldering iron to melt the solder from the LED's two pins on the printed circuit board.
    • Remove the LED from the circuit board while the solder is still melted.
  4. Durofix RV332 Battery LED Replacement: étape 4, image 1 de 2 Durofix RV332 Battery LED Replacement: étape 4, image 2 de 2
    • Place the positive leg of the new LED through the positive hole in the printed circuit board and solder it into place.
    • Place the negative leg of the LED through the negative hold in the printed circuit board and solder it into place.
Tyler Vincent
Membre depuis le 02/24/14
479 Réputation
4 tutoriels rédigés
Équipe
Michigan Tech, Team 5-5, Lauer Spring 2014 Membre de l'équipe Michigan Tech, Team 5-5, Lauer Spring 2014
MTU-LAUER-S14S5G5
3 membres
5 tutoriels rédigés
Un commentaire
Hello, I would ask the author about the type and model number of the electronic element marked as Q1 on the PCB (transistor or thyristor) on the third picture in Step 3 of this article, because mine is burnt out, and on this picture can't be read anything.
Greetings,
Plam
Пламен Петракиев - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 4
Total : 1,090
