Aller au contenu principal
Eclipse 180G2 MP3 Video Player LCD screen Replacement
Ce dont vous avez besoin
  1. Eclipse 180G2 MP3 Video Player LCD screen Replacement, Outer Case: étape 1, image 1 de 2 Eclipse 180G2 MP3 Video Player LCD screen Replacement, Outer Case: étape 1, image 2 de 2
    • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
    • Use a spudger to remove the plastic plate from the bottom of the player.
  2. Eclipse 180G2 MP3 Video Player LCD screen Replacement, Remove inner circuit from case shell: étape 2, image 1 de 3 Eclipse 180G2 MP3 Video Player LCD screen Replacement, Remove inner circuit from case shell: étape 2, image 2 de 3 Eclipse 180G2 MP3 Video Player LCD screen Replacement, Remove inner circuit from case shell: étape 2, image 3 de 3
    • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
    • Use the spudger to push the USB port on the bottom of the device inward.
    • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
  3. Eclipse 180G2 MP3 Video Player LCD screen Replacement, Removing the Screen: étape 3, image 1 de 1
    • Freed from the internal space of the device, the LCD screen as well as the buttons will simply fall out of the face of the device. They can now easily be replaced.
Jesse Minor
Membre depuis le 01/15/15
662 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 1-4, Tanski Winter 2015 Membre de l'équipe USF Tampa, Team 1-4, Tanski Winter 2015
USFT-TANSKI-W15S1G4
4 membres
5 tutoriels rédigés
Un commentaire
"Very difficult" may be a little exaggerated. I would put the difficulty level at either "Easy" or "Moderate".
hstrobl - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 1,256
