Aller au contenu principal
Eclipse 180G2 Outer Case Replacement
Ce dont vous avez besoin
  1. Eclipse 180G2 Outer Case Replacement, Outer Case: étape 1, image 1 de 2 Eclipse 180G2 Outer Case Replacement, Outer Case: étape 1, image 2 de 2
    • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
    • Use a spudger to remove the plastic plate from the bottom of the player.
  2. Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: étape 2, image 1 de 3 Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: étape 2, image 2 de 3 Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: étape 2, image 3 de 3
    • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
    • Use the spudger to push the USB port on the bottom of the device inward.
    • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
3 autres ont terminé cette réparation.
Jesse Minor
Membre depuis le 01/15/15
662 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 1-4, Tanski Winter 2015 Membre de l'équipe USF Tampa, Team 1-4, Tanski Winter 2015
USFT-TANSKI-W15S1G4
4 membres
5 tutoriels rédigés
Un commentaire
What if there is no charge port or USB port there no longer?
May 303 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 13
Total : 1,341
