Aller au contenu principal
Engine Brake Disassembly
Ce dont vous avez besoin
  1. Engine Brake Disassembly, Remove spring and brackets: étape 1, image 1 de 1
    • Remove the return spring by using needle nose pliers, a screwdriver, or other device. I removed the spring by the end of the front bracket (away from the mower handle). Lift up and away from the bracket, and the spring should come out.
    • Beware! The spring is very strong and injury could result if proper care is not exercised.
    • Remove the two bolts using a 7/16 socket.
  2. Engine Brake Disassembly, Remove alternator wire: étape 2, image 1 de 1
    • Push the metal tab closest to the black wire down
    • While pushing the tab down, pull the black wire out of the clip.
    • Disassembly is complete!
Jacob Micallef
Membre depuis le 03/06/17
993 Réputation
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 233
