Introduction
This guide shows how to replace an Ink Cartridge. This process requires no necessary tools or knowledge of the device.
Outils
Aucun outil requis.
Pièces
Open cover of the printer. Open the cartridge cover by pressing down on the tab and lifting it up.
  • Open cover of the printer.
  • Open the cartridge cover by pressing down on the tab and lifting it up.
Ajouter un commentaire
Grab the sides of the ink cartridge and pull it out. Replace ink cartridge with brand new ink cartridge.
  • Grab the sides of the ink cartridge and pull it out.
  • Replace ink cartridge with brand new ink cartridge.
Close cartridge cover. Close cover of the printer.
  • Close cartridge cover.
  • Close cover of the printer.
Larry Huang
Membre depuis le 12/10/2011
695 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 17-11, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 17-11, Regan Fall 2011
CPSU-REGAN-F11S17G11
4 membres
6 tutoriels rédigés
I cannot change the ink cartridges because when I press the Ink button they will not stop in a position where I can open the container. Nothing I've tried works -- can you help please? URGENT!!!
David Hardy - Réponse
I actually found this quite easy because of your guide. There was no issue at all with replacing the ink cartridge in my printer and now I can print again! Is there anything else I need to worry about after I put the cartridge in? http://tonertown.com.au
chrishowell562 - Réponse
You missed the part where you tell people how to get the cartridge to a position where you can open it. Mine is block because it is over to the side too far.
Paul M - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 44
Total : 7,285
