Pièces
Aucune pièce nécessaire.
Insert the flat end of a spudger on both sides of the wiring box to open and detach the box from the clock. Insert the flat end of a spudger on both sides of the wiring box to open and detach the box from the clock. Insert the flat end of a spudger on both sides of the wiring box to open and detach the box from the clock.
  • Insert the flat end of a spudger on both sides of the wiring box to open and detach the box from the clock.
Ajouter un commentaire
remove the box with your fingers.
  • remove the box with your fingers.
Detach the wires that connect the wiring to the battery compartment and the copper cylinder by using soldering iron. Detach the wires that connect the wiring to the battery compartment and the copper cylinder by using soldering iron.
  • Detach the wires that connect the wiring to the battery compartment and the copper cylinder by using soldering iron.
Using your hand remove the wiring box and replace it with a new one. Using your hand remove the wiring box and replace it with a new one.
  • Using your hand remove the wiring box and replace it with a new one.
Alaa
Membre depuis le 27/10/2014
228 Réputation
2 tutoriels rédigés
Équipe
Is there someone I can send my alarm clock to for fixing? IF so, how much would it cost? I do not have the tools nor the know how to do it. Most likely, the alarm will have to be replaced. The little motor on the inside is not working when it is time for it to go off. It does not move the ringer/clanger. Thanks,
mariacarbonell@comcast.net
Maria Carbonell - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 34
Total : 1,076
