Pièces
Aucune pièce nécessaire.
Make sure that your vacuum is unplugged from a power source. Press the black button just below the handle and extend the pole fully.
  • Make sure that your vacuum is unplugged from a power source.
  • Press the black button just below the handle and extend the pole fully.
Ajouter un commentaire
Press the black separator switch to separate the top and bottom halves of the vacuum. Press the black separator switch to separate the top and bottom halves of the vacuum.
  • Press the black separator switch to separate the top and bottom halves of the vacuum.
Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown. Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing. Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
  • Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
  • Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
    • Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
Pull out the button and the spring attached to it.
  • Pull out the button and the spring attached to it.
  • Swap the old spring with a new one.
Insert the new spring and button back into the right slot as shown in the picture.
  • Insert the new spring and button back into the right slot as shown in the picture.
Nikhila Vijaybhaskar
Membre depuis le 24/09/2013
224 Réputation
2 tutoriels rédigés
Équipe
University of Maryland, Team 1-1, Gulbrandsen Fall 2013 Membre de l'équipe University of Maryland, Team 1-1, Gulbrandsen Fall 2013
UMD-GULBRANDSEN-F13S1G1
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 191
