Introduction
If you determine there is no suction at the end of the hose, this guide will help you to replace a damaged hose.
On the back of the vacuum, pull the handle connected to the hose away from the vacuum. On the back of the vacuum, pull the handle connected to the hose away from the vacuum.
  • On the back of the vacuum, pull the handle connected to the hose away from the vacuum.
Ajouter un commentaire
Grasp the thick smooth collar at the bottom of the hose and twist left (counterclockwise) to remove the hose. Grasp the thick smooth collar at the bottom of the hose and twist left (counterclockwise) to remove the hose.
  • Grasp the thick smooth collar at the bottom of the hose and twist left (counterclockwise) to remove the hose.
Celina Burchett
Membre depuis le 13/10/2014
1 031 Réputation
8 tutoriels rédigés
Équipe
Clemson, Team 2-2, Benson Fall 2014 Membre de l'équipe Clemson, Team 2-2, Benson Fall 2014
CLEM-BENSON-F14S2G2
4 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 14
Total : 950
