Aller au contenu principal
Fahrenheit FHT 125PRMR Heating Plate Replacement
Ce dont vous avez besoin
  1. Fahrenheit FHT 125PRMR Heating Plate Replacement, Heating Plate: étape 1, image 1 de 1
    • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
  2. Fahrenheit FHT 125PRMR Heating Plate Replacement: étape 2, image 1 de 1
    • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
  3. Fahrenheit FHT 125PRMR Heating Plate Replacement: étape 3, image 1 de 2 Fahrenheit FHT 125PRMR Heating Plate Replacement: étape 3, image 2 de 2
    • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
    • When the pin is removed the two sides of the device can now separate.
    • Be sure to collect the spring that is next to the hinge when they are separated.
  4. Fahrenheit FHT 125PRMR Heating Plate Replacement: étape 4, image 1 de 1
    • Using Philips head (PH1) remove the 6 mm black screw that was underneath the spring as well as the 6 mm black screw next to the heating plate. Remove the panel the screws were holding down.
  5. Fahrenheit FHT 125PRMR Heating Plate Replacement: étape 5, image 1 de 1
    • Using Philips head (PH1) remove the two 4 mm silver screws on the sides of dial panel cover
  6. Fahrenheit FHT 125PRMR Heating Plate Replacement: étape 6, image 1 de 2 Fahrenheit FHT 125PRMR Heating Plate Replacement: étape 6, image 2 de 2
    • Using Philips head (PH00) to remove the 4 mm silver screw on the dial. Remove the dial with your hand.
  7. Fahrenheit FHT 125PRMR Heating Plate Replacement: étape 7, image 1 de 1
    • Remove the covering panel by pulling up with your hand.
  8. Fahrenheit FHT 125PRMR Heating Plate Replacement: étape 8, image 1 de 1
  9. Fahrenheit FHT 125PRMR Heating Plate Replacement: étape 9, image 1 de 2 Fahrenheit FHT 125PRMR Heating Plate Replacement: étape 9, image 2 de 2
    • Remove 3 sliver screws (3mm) (PH1) from the motherboard.
  10. Fahrenheit FHT 125PRMR Heating Plate Replacement: étape 10, image 1 de 1
Omar El Mounayri
Membre depuis le 09/29/16
61 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 2-2, Harley Fall 2016 Membre de l'équipe IUPUI, Team 2-2, Harley Fall 2016
IUPUI-HARLEY-F16S2G2
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 15
Total : 2,118
