Aller au contenu principal
Fast Fix Box Cutter Blade Replacement
Ce dont vous avez besoin
  1. Fast Fix Box Cutter Blade Replacement, Blade: étape 1, image 1 de 3 Fast Fix Box Cutter Blade Replacement, Blade: étape 1, image 2 de 3 Fast Fix Box Cutter Blade Replacement, Blade: étape 1, image 3 de 3
    • The case screw can easily be removed by using a Stanley #2 screwdriver or any other #2 screwdriver.
  2. Fast Fix Box Cutter Blade Replacement: étape 2, image 1 de 1
    • Separate casing by simply pulling apart both halves.
  3. Fast Fix Box Cutter Blade Replacement: étape 3, image 1 de 2 Fast Fix Box Cutter Blade Replacement: étape 3, image 2 de 2
    • Carefully, using the pull tab, take out the blade holder and set it on the table.
    • Remove the blade by carefully sliding it out of the holder.
    • Be very careful when dealing with the blade as it is sharp.
  4. Fast Fix Box Cutter Blade Replacement: étape 4, image 1 de 2 Fast Fix Box Cutter Blade Replacement: étape 4, image 2 de 2
    • Replace the old blade with the new blade by carefully sliding it into the blade holder.
    • Place the blade holder back into the casing using the pull tab to hold it.
  5. Fast Fix Box Cutter Blade Replacement: étape 5, image 1 de 2 Fast Fix Box Cutter Blade Replacement: étape 5, image 2 de 2
    • Add grease to the sliding mechanism
    • Use either a paper towel or a cloth to spread the grease around the sliding mechanism.
  6. Fast Fix Box Cutter Blade Replacement: étape 6, image 1 de 2 Fast Fix Box Cutter Blade Replacement: étape 6, image 2 de 2
    • Take the other half without the blade and put it back together with the other half with the blade.
    • Snap the two parts together.
    • Place the screw back in to hole while holding the casing together.
  7. Fast Fix Box Cutter Blade Replacement: étape 7, image 1 de 2 Fast Fix Box Cutter Blade Replacement: étape 7, image 2 de 2
    • Use Stanley #2, or any other #2, screwdriver to screw the casing back together.
    • To ensure proper placement of the blade, activate the mechanism that slides the blade out.
    • Once it comes out, like in second picture, you are done.
Peace Adeyemo
Membre depuis le 02/22/18
145 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 22
30 derniers jours : 50
Total : 8,905
