Aller au contenu principal
Felt Z85 Brake Pad Replacement
Ce dont vous avez besoin
  1. Felt Z85 Brake Pad Replacement, Remove Wheel: étape 1, image 1 de 3 Felt Z85 Brake Pad Replacement, Remove Wheel: étape 1, image 2 de 3 Felt Z85 Brake Pad Replacement, Remove Wheel: étape 1, image 3 de 3
    • Pull up on brake-release lever to spread pads for easy access.
    • Release lever on the right side of the wheel.
    • Loosen left nut on wheel until wheel comes free.
  2. Felt Z85 Brake Pad Replacement, Remove Pad(s): étape 2, image 1 de 3 Felt Z85 Brake Pad Replacement, Remove Pad(s): étape 2, image 2 de 3 Felt Z85 Brake Pad Replacement, Remove Pad(s): étape 2, image 3 de 3
    • Locate Brake Caliper.
    • Use 4.0 mm allen key to remove main bolt.
    • Rotate counterclockwise to loosen.
    • Be careful not to lose both the washer and spacer found in-between the bolt and the brake pad mounting hole.
    • Repeat step 2 to remove the pad on the other side.
  3. Felt Z85 Brake Pad Replacement, Collecting parts (reinstall): étape 3, image 1 de 2 Felt Z85 Brake Pad Replacement, Collecting parts (reinstall): étape 3, image 2 de 2
    • Brake Pad: The item being replaced.
    • Spacer: This item will be reused.
    • Washer: This item will be reused.
    • 4 mm hex bolt.
    • Note order of mounting hardware for reinstall.
Ryan Marschall
Membre depuis le 10/11/14
123 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 1-21, Donnelly Fall 2014 Membre de l'équipe USF Tampa, Team 1-21, Donnelly Fall 2014
USFT-DONNELLY-F14S1G21
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 1,018
