Aller au contenu principal
Fender 65 Twin Reverb Speaker Replacement
Ce dont vous avez besoin
  1. Fender 65 Twin Reverb Speaker Replacement, Speaker: étape 1, image 1 de 2 Fender 65 Twin Reverb Speaker Replacement, Speaker: étape 1, image 2 de 2
    • Make sure to unplug the power cord!
    • Take off the back panel by unscrewing the four Phillips head screws on the back of the amplifier.
    • Keep the screws in a safe place and mark what part they are for.
  2. Fender 65 Twin Reverb Speaker Replacement: étape 2, image 1 de 2 Fender 65 Twin Reverb Speaker Replacement: étape 2, image 2 de 2
    • Make sure to unplug the power cord and have the amplifier turned off.
    • Unplug the audio cable running from the port labeled "INT. Speakers" to the audio speakers.
    • You should know have clean access to the speakers.
  3. Fender 65 Twin Reverb Speaker Replacement: étape 3, image 1 de 3 Fender 65 Twin Reverb Speaker Replacement: étape 3, image 2 de 3 Fender 65 Twin Reverb Speaker Replacement: étape 3, image 3 de 3
    • Locate the wire leads on the speaker that you are replacing. Notice that there are three wires and four connections.
    • Note where each wire goes. (White is positive and black is negative.
    • Remove the wires from the speaker leads.
  4. Fender 65 Twin Reverb Speaker Replacement: étape 4, image 1 de 3 Fender 65 Twin Reverb Speaker Replacement: étape 4, image 2 de 3 Fender 65 Twin Reverb Speaker Replacement: étape 4, image 3 de 3
    • Remove all the screws on the perimeter of the speaker. Use locking pliers to remove the nuts. There are eight bolts holding the speaker in place.
    • Pull the old speaker off of the board and insert the new speaker the same way you removed the old one.
    • When tightening the nuts back down on the bolts, be sure to tighten them by alternating, working in diagonals. (i.e. once you tighten one down go diagonal from it and work on the next one.
    • Repeat with the other speaker if necessary.
4 autres ont terminé cette réparation.
Pièces jointes
Ryan Brown
Membre depuis le 02/20/14
210 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 9-27, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 9-27, Maness Winter 2014
CPSU-MANESS-W14S9G27
5 membres
7 tutoriels rédigés
2 commentaires
Thanks for the tutorial.
csharpconsultant - Réponse
Am I missing a step here? You have the chassis in the way to access to speakers. Do u remove the chassis or do you remove the tolex with the speakers attached to it? Thanks
Albert - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 30
Total : 6,326
