Aller au contenu principal
Fender Frontman 15r Fuse Replacement
Ce dont vous avez besoin
  1. Fender Frontman 15r Fuse Replacement, Fuse: étape 1, image 1 de 3 Fender Frontman 15r Fuse Replacement, Fuse: étape 1, image 2 de 3 Fender Frontman 15r Fuse Replacement, Fuse: étape 1, image 3 de 3
    • Be sure to unplug the device before proceeding.
    • Insert any tool with a small, flat end (such as a spudger, flathead screwdriver or plastic opening tool) into the groove in the bottom of the power input and wedge the plastic slot out from the amp.
    • There will be two compartments (one enclosed, one exposed) each containing a fuse. The exposed fuse is the active fuse and the enclosed one is a spare.
  2. Fender Frontman 15r Fuse Replacement: étape 2, image 1 de 2 Fender Frontman 15r Fuse Replacement: étape 2, image 2 de 2
    • Remove the blown exposed fuse and replace it with the enclosed fuse. If there is not an extra enclosed fuse, a new fuse must be ordered and inserted into the exposed slot.
Stephen Figueira
Membre depuis le 10/04/12
140 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 24-30, Regan Fall 2012 Membre de l'équipe Cal Poly, Team 24-30, Regan Fall 2012
CPSU-REGAN-F12S24G30
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 44
Total : 13,429
