Introduction
This guide will show you how to reset the GLOD.
While the PS3 is on (green LED on), put the PS3 into standby mode (red power LED) by pressing the power button for 5 seconds.
  • While the PS3 is on (green LED on), put the PS3 into standby mode (red power LED) by pressing the power button for 5 seconds.
Ajouter un commentaire
Now when the PS3 is in standby mode, hold the power button down until you hear it beep about 2 or 3 times, then release the power button.
  • Now when the PS3 is in standby mode, hold the power button down until you hear it beep about 2 or 3 times, then release the power button.
about 2 or 3, which is it, or which is it supposed to be? I can get the two beeps and once i thought i heard three...i'm thinking 3 is the reset, but the system won't do it.?
athirdbaseman - Réponse
i held that button down for a min or two i got one beep and it came on but still a black screen and iv done this over and over are there any known causes of this issue?
Roger Leclerc - Réponse
My son was playing mine and the screen became all pixelated with white lines.
My understanding as I did find a YouTube video that shows the same thing as mine did. Is that the gpu hasn't went bad but needs to be reflowed or reballed.
I would tell you if it worked or not but when I was putting it back together I broke off the clip on the motherboard that the ribbon cable plugs into from the eject and on and off board.
So my recommendation would be try a reflow.
Eric Spurlock -
This will reset the video settings to the lowest settings and when you start the PS3 with  HDMI or PS3 AV cable connected, it will go through the setup process and you will now see a picture on the TV screen.
  • This will reset the video settings to the lowest settings and when you start the PS3 with HDMI or PS3 AV cable connected, it will go through the setup process and you will now see a picture on the TV screen.
Ligne d'arrivée
59 autre(s) ont terminé cette réparation.
Tim Gelvin
Membre depuis le 02/11/2010
3 832 Réputation
1 tutoriel rédigé
Équipe
Master Techs Membre de l'équipe Master Techs
Community
277 membres
724 tutoriels rédigés
20 commentaires
I have tried this multiple times, even took up a few hints about removing the HDD and putting it back in, and then trying.... it still did not work.... does any one have any idea of how to REALLY fix this?!
codylawinger - Réponse
does not work for me i have a slim model. still striving to find a solution.
krn - Réponse
I have also been searching endlessly for a solution to this problem for my CECH-2001A model PS3 Slim. The majority of the time my system turns on with the GLOD. The rest of the time it works perfectly. I've tried safe mode and went through all the steps numerous times. I've also tried three different hard drives, two different HDMI cables and two different tv's. None of which alleviate the problem. I've also replaced the thermal paste and am religious with keeping it dust free. The only other solution I've found is that the RSX may be the culprit. Other than that, I'm at a loss.
David - Réponse
This does not work for me. I get one beep (on) then one beep (off) then it goes red. I have a CECHL01 model. Still no video. Will a reflow also help HDMI loss?
James - Réponse
aww man it did not work for me
StevenSon654 Gaming Channel - Réponse
I pressed the Power button for 5 sec every &&^&^$^ time and nothing happen plz help meh lor gabe!
kenanauberger - Réponse
Nope didn't work as usual.... Why does Sony have to be complicated I'm pretty sure it's got to be more than this...
traveen kavith - Réponse
i've tried so many times by switch off and beep 3 times swithc onn...and finally by doing this my hard disk failed. i just baught new hdd but still the same. HDMI not working. god
bharani - Réponse
Now what to do when it got on the safe mode?
Rahul Mohabir - Réponse
RSX reflow, the solder joints could be cracked on the GPU. This is a video reset.
Brian Kohls - Réponse
Can put some coins (with only some copper) with up the rsx chip and back works fine.
With better length.
Fábio Santos - Réponse
Hi all.
Has anyone actually found a working solution for this problem ?
My ' Fat ' PS3 has the exact same problem,no video or sound.
My PS3 boots up as normal,and sounds normal,but no sound or video through the HDMI,and the same with the original AV cable.???
Cheers
Colin - Réponse
Maybe I can help you
Alex Cela -
After you get through this, when you see the options.
Which one should I choose?
majorosbence01 - Réponse
Guys maybe I found how to fix
Alex Cela - Réponse
what is it??
kenneth soto -
Any chance ,how can you help with the GLOD
James Dobies -
Please send your suggestion on the GLOD for Fat PS3
James Dobies -
hi there I notice anybody on here is trying to fix their playstation 3 themselves but my suggestion is not going to sony and get it shipped out and pay over 200 hundred dollars!there is another way click on this link and hopefully this may help you.good luck! '''http://tinyurl.com/ycalqnf4'''
Ricu Martini - Réponse
I have a December 2006 FAT PS3 and no help still no vid
Lagercat - Réponse
Voir les statistiques:
Dernières 24 heures : 24
7 derniers jours : 185
30 derniers jours : 640
Total : 107,399
