Aller au contenu principal
Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm
Ce dont vous avez besoin
  1. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm, Opening the Device: étape 1, image 1 de 1
    • Flip device upside down and remove the 4 foam pads at each corner.
    • Remove the 4 screws using a Philips Screwdriver.
    • Gently lift the case off of the body and set down in a safe place.
  2. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm, Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm: étape 4, image 1 de 1
    • Unscrew the 5 screws in the base circuit board.
  3. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm: étape 5, image 1 de 1
    • Use the tweezers to slightly lift the circuit board, allowing the cylindrical alarm piece to slide out.
  4. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm: étape 6, image 1 de 1
    • Check if the wires are secured.
    • If they are not attached, you may re-solder it together. If they are attached, that means it is a faulty alarm and should replace it.
3 autres ont terminé cette réparation.
Nicholas Roppolo
Membre depuis le 10/25/13
384 Réputation
3 tutoriels rédigés
Équipe
University of Maryland, Team 4-2, Vijaybhaskar Fall 2013 Membre de l'équipe University of Maryland, Team 4-2, Vijaybhaskar Fall 2013
UMD-VIJAYBHASKAR-F13S4G2
2 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 29
30 derniers jours : 45
Total : 1,351
