Aller au contenu principal
Floor Pump Drive Hose Replacement
Ce dont vous avez besoin
  1. Floor Pump Drive Hose Replacement, Drive Hose: étape 1, image 1 de 3 Floor Pump Drive Hose Replacement, Drive Hose: étape 1, image 2 de 3 Floor Pump Drive Hose Replacement, Drive Hose: étape 1, image 3 de 3
    • Use a pair of pliers to loosen the hose pinch by turning it counterclockwise a couple of turns.
    • Continue to loosen the hose pinch by hand until it comes free from its threads.
    • Slide the hose pinch down the tube so that it does not interfere with removing the hose.
  2. Floor Pump Drive Hose Replacement: étape 2, image 1 de 3 Floor Pump Drive Hose Replacement: étape 2, image 2 de 3 Floor Pump Drive Hose Replacement: étape 2, image 3 de 3
    • Using a hobby knife, carefully slice a slit in the bottom of the hose to allow it to slide off.
    • Be careful and go slowly so as not to damage the nipple underneath.
    • Use a metal prying tool or flathead screwdriver to pry the hose up off of the nipple.
    • Remove the hose from the pump.
  3. Floor Pump Drive Hose Replacement: étape 3, image 1 de 2 Floor Pump Drive Hose Replacement: étape 3, image 2 de 2
    • Slide the hose pinch off of the end of the old hose and onto the new hose.
    • Be sure that the threaded end of the hose pinch faces toward the open end of the new hose.
  4. Floor Pump Drive Hose Replacement: étape 4, image 1 de 3 Floor Pump Drive Hose Replacement: étape 4, image 2 de 3 Floor Pump Drive Hose Replacement: étape 4, image 3 de 3
    • Use a metal rod or screwdriver to widen the new hose so that it will fit over the nipple.
    • Slide the hose in place.
    • Push down on the hose clamp while twisting it clockwise to thread it in place.
Ligne d'arrivée
iRobot
Membre depuis le 09/24/09
1 Réputation
636 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 10
Total : 2,117
