Introduction
We will start by removing the wheel and removing any debris that may be obstructing motion, and then reattach the wheel to the axle of the chair.
Familiarize yourself with the tools required for this guide by reading through the Free Wheelchair Mission Tools Maintenance Guide.
Pièces
Aucune pièce nécessaire.
Use the socket head of the 19mm wrench to unscrew the nut that connects the castor wheel’s fork to the steel frame Remove the wheel from the small steel frame
  • Use the socket head of the 19mm wrench to unscrew the nut that connects the castor wheel’s fork to the steel frame
  • Remove the wheel from the small steel frame
Ajouter un commentaire
Hold the bolt that connects the wheel to the fork with pliers This keeps the bolt through the wheel from rotating Use the socket head of the 10 mm wrench in your other hand to remove the nut on the other end of the bolt
  • Hold the bolt that connects the wheel to the fork with pliers
    • This keeps the bolt through the wheel from rotating
  • Use the socket head of the 10 mm wrench in your other hand to remove the nut on the other end of the bolt
Flip wheel over and remove the bolt Remove the castor wheel Remove the castor wheel
  • Flip wheel over and remove the bolt
  • Remove the castor wheel
Check for and remove any debris from the wheel or wheel axle that may be obstructing motion of the wheel
  • Check for and remove any debris from the wheel or wheel axle that may be obstructing motion of the wheel
Alyssa Chaney
Membre depuis le 22/04/2013
49 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 14-7, Maness Spring 2013 Membre de l'équipe Cal Poly, Team 14-7, Maness Spring 2013
CPSU-MANESS-S13S14G7
5 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 976
