Introduction
The LCD screen is required to operate your camera. If yours is not working, it needs to be replaced. This guide will show you how to do that.
Pièces
Aucune pièce nécessaire.
Unscrew the six 3.5mm Philips head from the outer casing. Unscrew the six 3.5mm Philips head from the outer casing. Unscrew the six 3.5mm Philips head from the outer casing.
  • Unscrew the six 3.5mm Philips head from the outer casing.
Ajouter un commentaire
Open the battery chamber and remove the battery. Pry the front half of the casing from the camera. Be careful that the sensor cover—the small piece of translucent plastic—doesn't fall out of place. Return it to its original location if it does.
  • Open the battery chamber and remove the battery.
  • Pry the front half of the casing from the camera.
  • Be careful that the sensor cover—the small piece of translucent plastic—doesn't fall out of place. Return it to its original location if it does.
Pry the back half of the casing from the camera. Be careful when maneuvering the camera without the casing on as the LCD screen is not fastened to anything.
  • Pry the back half of the casing from the camera.
  • Be careful when maneuvering the camera without the casing on as the LCD screen is not fastened to anything.
Lift the LCD screen out of the camera. There is a tab that keeps in place the ribbon that attaches the screen and motherboard. Lift this up using the spudger and disconnect the screen from the motherboard. There is a tab that keeps in place the ribbon that attaches the screen and motherboard. Lift this up using the spudger and disconnect the screen from the motherboard.
  • Lift the LCD screen out of the camera.
  • There is a tab that keeps in place the ribbon that attaches the screen and motherboard. Lift this up using the spudger and disconnect the screen from the motherboard.
George Lindner
Membre depuis le 20/01/2015
237 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 19-3, Blackwell Winter 2015 Membre de l'équipe USF Tampa, Team 19-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G3
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 3
Total : 290
