Introduction
We will walk through removal the USB port from the Fujitsu Lifebook Stylistic Q584.
Remove the white sticker covering the screws (if applicable)
  • Remove the white sticker covering the screws (if applicable)
  • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
Ajouter un commentaire
Insert the plastic opening tool along seam of back case.
  • Insert the plastic opening tool along seam of back case.
  • Gently slide the plastic opening tool along entire seam popping the clips free.
Carefully lift the back case and remove smartcard ribbon from motherboard.
  • Carefully lift the back case and remove smartcard ribbon from motherboard.
Remove the ten 3mm screws with a  PH00 screwdriver from the shield.
  • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
Kits RAM pour Mac
Accélérez votre Mac. Maximisez sa mémoire.
Kits RAM pour Mac
Augmentez la mémoire de votre Mac.
Remove the grey docking station port cover
  • Remove the grey docking station port cover
Lift the shield away from the device and remove the fingerprint scanners ribbon from the motherboard.
  • Lift the shield away from the device and remove the fingerprint scanners ribbon from the motherboard.
Remove 2mm screw with a  PH1 screwdriver from USB board
  • Remove 2mm screw with a PH1 screwdriver from USB board
Disconnect USB periphery ribbon from motherboard
  • Disconnect USB periphery ribbon from motherboard
Pull USB board up to remove.
  • Pull USB board up to remove.
Spencer Bacon
Membre depuis le 21/09/2017
401 Réputation
4 tutoriels rédigés
Équipe
Washington State, Team S1-G3, Phelps-Hillen Fall 2017 Membre de l'équipe Washington State, Team S1-G3, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S1G3
5 membres
10 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 41
