Introduction
The solar cooker assembly should be performed in an large open area with nothing that obstructs the sunlight. We recommend at least two people for the quickest and easiest assembly.
Ce dont vous avez besoin
An inventory for all parabolic solar cooker parts follows below.
6 Reflective Dish Sections
1 Expansion Pipe
1 Tripod Center Plate
1 T-Bar
3 Tripod Base Legs
1 Cooker Flat
1 Pipe Ring
Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
Center the bottom of the expansion pipe between the tabs of the t-bar bracket. Insert a 14mm bolt through the bracket and expansion pipe and hand thread a nut. Use 14mm wrenches to secure the assembly.
Lay two triangular sections side-by-side with pointed edges and bases adjacent to each other.
Use the 10 mm nuts and bolts to attach the two plates together. First, hand thread each bolt/nut pair, then use two 10 mm wrenches secure them.
DO NOT install a nut and bolt in the THIRD hole from the center (pointed end of the section). This is where the Pipe Ring Bracket is attached later on.
Place the assembled solar panel dish face down with the metal brackets on the top and facing up.
Set the pipe ring in the metal brackets circling the center of the dish.
Slide the cross bearer into the two holes in the support ring making sure the top of the cross sticks through the center of the solar panel dish.
Insert a 14mm bolt into the metal bracket on the support ring through the adjustable arm and secure with a nut.
Tighten with your hands.
To disassemble your device, follow these instructions in reverse order.
2 autres ont terminé cette réparation.
3 commentaires
Thank you very much ,mine came without the instructions so this has been so helpful
Hi everyone, I want to ask about the material used over the dish. whether it's concave mirror or some sheet. kindly someone clear my confusion. Thank you
