Aller au contenu principal
GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement
Ce dont vous avez besoin
  1. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery Compartment Cover: étape 1, image 1 de 3 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery Compartment Cover: étape 1, image 2 de 3 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery Compartment Cover: étape 1, image 3 de 3
    • Find the battery compartment on the bottom of the clock radio.
    • Using your thumb, push the compartment cover latch toward the battery.
    • With the latch pushed in, pull the compartment cover upward to remove it..
  2. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery: étape 2, image 1 de 2 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Battery: étape 2, image 2 de 2
    • Lift the battery from the compartment.
    • Pull the battery up and gently disconnect it from the battery connector.
  3. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Screws: étape 3, image 1 de 2 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Screws: étape 3, image 2 de 2
    • Using a Phillips #00 Screwdriver, unscrew the six 12mm screws from around the bottom of the clock radio.
  4. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, LCD Cover: étape 4, image 1 de 1
    • Gently pull the liquid crystal display (LCD) cover off.
  5. GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Clock Radio: étape 5, image 1 de 2 GE 7-4836B Alarm Clock AM-FM Radio Outer Case Replacement, Clock Radio: étape 5, image 2 de 2
    • Lift the top off. Two gray, plastic internal pieces will fall out when you do this; set them aside.
2 autres ont terminé cette réparation.
Dominick Giguere
Membre depuis le 10/28/14
848 Réputation
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 352
