Aller au contenu principal
Galaxy J3 Prime LCD Screen Replacement
Ce dont vous avez besoin
Vidéo d'introduction
    • Remove the back cover and battery.
    • Heat up the screen to loosen the adhesive.
    • You can use a iOpener or a hair drier, but make sure you don't get the phone too hot.
    • Put a spudger between the phone frame and the front display.
    • Remove the plastic bracket that will be visible when you pry up the screen.
    • Gently pull up on the LCD screen adhesive to remove the screen.
    • Remove the screws on the back of the phone frame that are holding the housing of the phone together.
    • Now that all of the screws have been removed, pull up the frame with a screwdriver or spudger.
    • Be gentle so you don't break anything.
    • Disconnect the metal flex cable from the charging port.
    • Remove the Motherboard from the housing.
9 autres ont terminé cette réparation.
Brian Brown
Membre depuis le 09/26/16
393 Réputation
1 tutoriel rédigé
3 commentaires
great guide, this really helped
anonymous 591 - Réponse
thanks for your help, this has really helped
Marvinhenderson4@gmail.com - Réponse
Best guide for a J3 out there professional and easy to follow
Keith Pobuta - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 17
Total : 6,967
