Introduction
How to remove the back housing of the Game Boy Color.
Pièces
Aucune pièce nécessaire.
Locate the battery compartment on the back of the Game Boy Color. Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  • Locate the battery compartment on the back of the Game Boy Color.
  • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
Ajouter un commentaire
Remove the batteries from the battery compartment.
  • Remove the batteries from the battery compartment.
Using a Y1 screwdriver, remove the six screws on the back of the device as pictured.  The bottom two screws are located inside of the battery compartment.
  • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
Gently lift and separate the back housing from the rest of the device.  Now you've got the back housing out! Gently lift and separate the back housing from the rest of the device.  Now you've got the back housing out!
  • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
7 autre(s) ont terminé cette réparation.
Angela Yoeurng
Membre depuis le 18/01/2013
938 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 19-47, Regan Winter 2013 Membre de l'équipe Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 membres
24 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 17
30 derniers jours : 51
Total : 3,150
