Introduction
Use the following guide to replace buttons in the device.
Remove the Phillips #00 screw on the side of the Game Boy closest to the directional pad. Once the screw has been loosened, lift the cover off the back of the device. Once the screw has been loosened, lift the cover off the back of the device.
  • Remove the Phillips #00 screw on the side of the Game Boy closest to the directional pad.
  • Once the screw has been loosened, lift the cover off the back of the device.
Ajouter un commentaire
Once the back cover is removed, you should see that the battery is connected to the device by two wires and a plastic connector. Gently grab the wires. Gently grab the wires.
  • Once the back cover is removed, you should see that the battery is connected to the device by two wires and a plastic connector.
  • Gently grab the wires.
I heard of someone doing this and the connecter got stuck in the plug. Is there any other way to do it?
Lucas Hoekstra (Lucas9810) - Réponse
Carefully pull the wires until the connector comes out of the device. Be careful! Don't pull too hard, or you may rip the wires out from the connector.
  • Carefully pull the wires until the connector comes out of the device.
  • Be careful! Don't pull too hard, or you may rip the wires out from the connector.
  • When putting the battery back into the device, make sure the connector is put in exactly the way it came out.
Locate the two circular holes on the side of the Game Boy nearest to the directional pad. Locate the two circular holes on the side of the Game Boy nearest to the directional pad.
  • Locate the two circular holes on the side of the Game Boy nearest to the directional pad.
Straighten the end of a paper clip and push it into each of the circular holes. You may hear a faint click afterwards. Use the paper clip to lever the faceplate off from the unit.
  • Straighten the end of a paper clip and push it into each of the circular holes.
  • You may hear a faint click afterwards.
  • Use the paper clip to lever the faceplate off from the unit.
Remove the two tri-wing screws on the top of the Game Boy and the two screws next to the volume/contrast switch. Remove the two tri-wing screws on the top of the Game Boy and the two screws next to the volume/contrast switch. Remove the two tri-wing screws on the top of the Game Boy and the two screws next to the volume/contrast switch.
  • Remove the two tri-wing screws on the top of the Game Boy and the two screws next to the volume/contrast switch.
It would be clearer if this were listed as 2 bullet points.
Spencer W - Réponse
MANTA DRIVER KIT
112 bit driver kit $59.99
MANTA DRIVER KIT
Remove the three Phillips #00 screws. Remove the two tri-wing screws. Remove the two tri-wing screws.
  • Remove the three Phillips #00 screws.
  • Remove the two tri-wing screws.
Lift the back cover off of the Game Boy. Lift the back cover off of the Game Boy. Lift the back cover off of the Game Boy.
  • Lift the back cover off of the Game Boy.
Remove the two Phillips #00 screws from the plastic frame. As you are pulling off the plastic frame, the shoulder buttons and the volume switch may fall out of the device. Underneath each shoulder button is a small spring. Do not lose them.
  • Remove the two Phillips #00 screws from the plastic frame.
  • As you are pulling off the plastic frame, the shoulder buttons and the volume switch may fall out of the device.
  • Underneath each shoulder button is a small spring. Do not lose them.
With a spudger, depress the small clip on the lower right corner of the plastic guard. Grab the edges of the plastic frame and lift the frame off the motherboard.
  • With a spudger, depress the small clip on the lower right corner of the plastic guard.
  • Grab the edges of the plastic frame and lift the frame off the motherboard.
Remove the two gold Phillips #00 screws from the motherboard.
  • Remove the two gold Phillips #00 screws from the motherboard.
It's easier and adds less risk of damaging the gold cable to remove the #00 motherboard screw by the d-pad between steps 12 and 13, after the motherboard has been removed from the front plate. This also makes it easier to reassemble if following the steps backwards.
Spencer W - Réponse
With one hand, gently slide the top left end of the motherboard up and out of the front case. With your other hand, pull out the EMI shield until the tab comes out of the front case.
  • With one hand, gently slide the top left end of the motherboard up and out of the front case.
  • With your other hand, pull out the EMI shield until the tab comes out of the front case.
  • Once the tab is pulled out from the bottom, slide the EMI shield down and out of the device.
The entire motherboard is now accessible. Take extreme care when working with the motherboard to avoid damaging the device and its components. A small ribbon cable connects the start and select buttons to the motherboard. It can rip very easily, so do not pull on it.
  • The entire motherboard is now accessible.
  • Take extreme care when working with the motherboard to avoid damaging the device and its components.
  • A small ribbon cable connects the start and select buttons to the motherboard. It can rip very easily, so do not pull on it.
  • Lift the motherboard and the front plastic cover assembly off of the front case.
  • Once the front case is removed, the plastic on/off switch will fall out of place.
When you remove the motherboard from the  front case, the start and select buttons may fall out. If the buttons do not fall out, remove them with a pair of tweezers. If the buttons do not fall out, remove them with a pair of tweezers.
  • When you remove the motherboard from the front case, the start and select buttons may fall out.
  • If the buttons do not fall out, remove them with a pair of tweezers.
Without the front case, you will be left with the motherboard and the plastic mount. The LCD screen is attached to the motherboard by a ribbon and can fall off the plastic mount. Using metal tweezers, grab the start/select board and slide it out gently. Using metal tweezers, grab the start/select board and slide it out gently.
  • Without the front case, you will be left with the motherboard and the plastic mount. The LCD screen is attached to the motherboard by a ribbon and can fall off the plastic mount.
  • Using metal tweezers, grab the start/select board and slide it out gently.
Lift the entire motherboard assembly off the plastic guard. Take caution not to damage any of the gold ribbon cables on the motherboard.
  • Lift the entire motherboard assembly off the plastic guard.
  • Take caution not to damage any of the gold ribbon cables on the motherboard.
  • The LCD screen is the only thing connecting the motherboard and plastic guard.
To remove the LCD screen, carefully angle it until it is diagonal to the square hole in the plastic guard and slide it out. It is now possible to remove the entire motherboard assembly from the plastic guard.
  • To remove the LCD screen, carefully angle it until it is diagonal to the square hole in the plastic guard and slide it out.
  • It is now possible to remove the entire motherboard assembly from the plastic guard.
On the plastic guard, there are two rubber pads that cover the buttons. Remove them. These pads rest on the motherboard and sometimes stick to it. If they do, peel them off. With the rubber pads off, you may use your fingers to remove the buttons to clean or replace them.
  • On the plastic guard, there are two rubber pads that cover the buttons. Remove them.
  • These pads rest on the motherboard and sometimes stick to it. If they do, peel them off.
  • With the rubber pads off, you may use your fingers to remove the buttons to clean or replace them.
  • When returning the buttons to the guard, they have to be put back in exactly the way they were pulled out.
4 autre(s) ont terminé cette réparation.
Jack
Membre depuis le 21/01/2010
243 Réputation
9 tutoriels rédigés
Équipe
Cal Poly, Team 8-46, Regan Winter 2010 Membre de l'équipe Cal Poly, Team 8-46, Regan Winter 2010
CPSU-REGAN-W10S8G46
5 membres
15 tutoriels rédigés
Buenas abra el modo de reparar o puentear la placa de los botones start y selec ya que el flex se rompió
Good open the way to repairing or bypassing the plate and start buttons selec since the flex broke
Jesus Briones - Réponse
Con ayuda de un cúter pela la terminales y solda nuevamente debes verificar si el flex tiene dos placas por ambos lados o solo es una
eshemoc - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 49
30 derniers jours : 215
Total : 14,321
