Aller au contenu principal
Garmin Approach S2 Battery Replacement
Ce dont vous avez besoin
  1. Garmin Approach S2 Battery Replacement, Back Cover: étape 1, image 1 de 2 Garmin Approach S2 Battery Replacement, Back Cover: étape 1, image 2 de 2
    • Remove the six T5 Torx 6.32mm screws securing the back cover to the watch.
  2. Garmin Approach S2 Battery Replacement: étape 2, image 1 de 1
    • Remove the back cover carefully.
    • Even after the screws have been removed, the back cover can still be quite difficult to take off. Moderate to extensive prying may be required. Be gentle, but firm.
  3. Garmin Approach S2 Battery Replacement, Battery: étape 3, image 1 de 1
    • On the back cover use a plastic opening tool to remove the green tape retaining the battery.
  4. Garmin Approach S2 Battery Replacement: étape 4, image 1 de 2 Garmin Approach S2 Battery Replacement: étape 4, image 2 de 2
    • Remove the green tape shrouding the battery connector.
  5. Garmin Approach S2 Battery Replacement: étape 5, image 1 de 2 Garmin Approach S2 Battery Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use the ESD safe tweezers to push the connector and metal shroud out from the back of the connector.
    • Remove the third and fourth wires from the right of the connector (as seen when looking from the angle in the photo). They should be red and black respectively.
    • DO NOT attempt to pull the wire from the connector, it will pull the wire from the metal shroud shown in the red box, which needs to be preserved for the connection to be successful.
  6. Garmin Approach S2 Battery Replacement: étape 6, image 1 de 1
    • Use the ESD safe tweezers to break the adhesive between the back cover and the battery.
    • Remove the battery.
  7. Garmin Approach S2 Battery Replacement: étape 7, image 1 de 1
    • Remove the green tape on the back of the battery, it can be reused later.
6 autres ont terminé cette réparation.
Emily Kovacs
Membre depuis le 03/21/18
259 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S4-G1, Baechle Spring 2018 Membre de l'équipe IUPUI, Team S4-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G1
3 membres
4 tutoriels rédigés
7 commentaires
If anyone is looking for the replacement battery for the Approach S2 it can be found here:
Replacement Battery for Garmin Approach S2
It also included the T5 Torx and Opening Tools that are needed.
michaelf33707 - Réponse
Step 6 shows 2 red wires each with a free end. One of these red wires has the non free end connected to the charging circuit terminal but there is no mention in Step 6 of disconnecting this wire or where the free end is connected to.
Paul Stevenson - Réponse
This is a great tutorial for the S2. In my case I accidentally dropped one metal shroud (referred to in Step 5). I scoured the area on my hands and knees to no avail. Can you direct me to where I might obtain this part?or perhaps the entire connector? Thank you….
Brian Mahoney - Réponse
Hi, Where the !&&* Can I buy a Replacement Battery for The Garmin S2 Golf watch.????.
Gregory John Wickenden - Réponse
Gregory, I got my replacement via Amazon (UK). Battery came from Germany in about 1 week. Not cheap, but a lot cheaper than a new watch.
john.joice - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 110
30 derniers jours : 383
Total : 37,742
