Aller au contenu principal
Garmin Approach S2 Motherboard Replacement
Ce dont vous avez besoin
  1. Garmin Approach S2 Motherboard Replacement, Back Cover: étape 1, image 1 de 2 Garmin Approach S2 Motherboard Replacement, Back Cover: étape 1, image 2 de 2
    • Remove the six T5 Torx 6.32mm screws securing the back cover to the watch.
  2. Garmin Approach S2 Motherboard Replacement: étape 2, image 1 de 1
    • Remove the back cover carefully.
    • Even after the screws have been removed, the back cover can still be quite difficult to take off. Moderate to extensive prying may be required. Be gentle, but firm.
  3. Attention : l'étape 3 est issue d'un tutoriel marqué comme en cours.
    Garmin Approach S2 Motherboard Replacement, Water Proof Gasket: étape 3, image 1 de 1
    • Remove the orange gasket.
  4. Garmin Approach S2 Motherboard Replacement, Screen: étape 4, image 1 de 1
    • Remove the screen and motherboard assembly from the case.
  5. Garmin Approach S2 Motherboard Replacement: étape 5, image 1 de 1
    • Use a metal spudger to remove the golden retaining clip from the screen. There will be some adhesive to break.
  6. Garmin Approach S2 Motherboard Replacement: étape 6, image 1 de 1
    • Remove the screen from the golden metal clip.
  7. Garmin Approach S2 Motherboard Replacement: étape 7, image 1 de 1
    • Unhinge the black retaining hinge by prying it open with the metal spudger; Your fingernails will work as well.
  8. Garmin Approach S2 Motherboard Replacement: étape 8, image 1 de 2 Garmin Approach S2 Motherboard Replacement: étape 8, image 2 de 2
    • Remove the connector from the motherboard by pulling it free at the base.
    • Make sure to pull from the base of the connector wire, as it is very easy to rip the wire from the screen.
  9. Garmin Approach S2 Motherboard Replacement: étape 9, image 1 de 1
    • Remove the screen from the motherboard.
    • Notice our tape retaining the connector to the screen. This is so easy to rip!
  10. Garmin Approach S2 Motherboard Replacement, Motherboard: étape 10, image 1 de 1
    • Remove the motherboard from the screen.
Evan Miller
Membre depuis le 03/21/18
250 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S4-G1, Baechle Spring 2018 Membre de l'équipe IUPUI, Team S4-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G1
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 687
