Aller au contenu principal
Garmin Fenix 3 HR Motherboard Replacement
Ce dont vous avez besoin
  1. Garmin Fenix 3 HR Motherboard Replacement, Motherboard: étape 1, image 1 de 2 Garmin Fenix 3 HR Motherboard Replacement, Motherboard: étape 1, image 2 de 2
    • Remove the five 7mm screws with H1.3 hex screwdriver.
  2. Garmin Fenix 3 HR Motherboard Replacement: étape 2, image 1 de 2 Garmin Fenix 3 HR Motherboard Replacement: étape 2, image 2 de 2
    • Use a plastic opening tool to remove the face of the device to expose the inner components.
    • There is one metal piece at the top of the face that is loose. This is the GPS antenna which will need to be removed as well.
    • Be careful of the ribbon that connects the motherboard to the display.
  3. Garmin Fenix 3 HR Motherboard Replacement: étape 3, image 1 de 1
    • Disconnect this ribbon from the motherboard using tweezers.
  4. Garmin Fenix 3 HR Motherboard Replacement: étape 4, image 1 de 2 Garmin Fenix 3 HR Motherboard Replacement: étape 4, image 2 de 2
    • Using a T5 screwdriver, remove the two 5mm screws.
    • The motherboard should move freely.
  5. Garmin Fenix 3 HR Motherboard Replacement: étape 5, image 1 de 1
    • Another ribbon is attached from the underside of the motherboard. Disconnect this ribbon.
  6. Garmin Fenix 3 HR Motherboard Replacement: étape 6, image 1 de 1
    • Disconnect wires connecting battery to motherboard.
  7. Garmin Fenix 3 HR Motherboard Replacement: étape 7, image 1 de 1
    • The battery is glued to the motherboard and will need pried off with a nylon spudger.
  8. Garmin Fenix 3 HR Motherboard Replacement: étape 8, image 1 de 1
    • Now attach battery to new motherboard and reassemble.
5 autres ont terminé cette réparation.
Jacob Smiley
Membre depuis le 03/26/18
277 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S1-G6, Harley Spring 2018 Membre de l'équipe IUPUI, Team S1-G6, Harley Spring 2018
IUPUI-HARLEY-S18S1G6
3 membres
4 tutoriels rédigés
2 commentaires
And where would one source replacement motherboard?
jonathan.hatchuel - Réponse
donde puedo encontras placa.madre reeemplazo????
luis zavala - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 16
Total : 4,753
