Aller au contenu principal
Garmin GPS V Front Plate Replacement
Ce dont vous avez besoin
  1. Garmin GPS V Front Plate Replacement, Logic Board: étape 1, image 1 de 3 Garmin GPS V Front Plate Replacement, Logic Board: étape 1, image 2 de 3 Garmin GPS V Front Plate Replacement, Logic Board: étape 1, image 3 de 3
    • Orient the GPS V backside up.
    • With a #0 Philips screwdriver, remove six M2x0.4 black screws on the back of the unit.
  2. Garmin GPS V Front Plate Replacement: étape 2, image 1 de 2 Garmin GPS V Front Plate Replacement: étape 2, image 2 de 2
    • With the spudger, gently pry the back plate off the unit starting at the corners.
    • Open the back plate about 35°, use the antenna side act like a hinge.
    • Do NOT remove the back plate all the way, there are cables connected to it.
  3. Garmin GPS V Front Plate Replacement: étape 3, image 1 de 2 Garmin GPS V Front Plate Replacement: étape 3, image 2 de 2
    • Locate the white 8-pin connector on the logic board and disconnect it.
    • Open the device all the way, making sure to not disconnect the brown antenna wire.
  4. Garmin GPS V Front Plate Replacement: étape 4, image 1 de 2 Garmin GPS V Front Plate Replacement: étape 4, image 2 de 2
    • With a #1 Philips screwdriver, remove the silver M2x0.4 screw on the logic board near the brown wire.
    • You may need to rotate the device to get better access to the screw.
  5. Garmin GPS V Front Plate Replacement: étape 5, image 1 de 3 Garmin GPS V Front Plate Replacement: étape 5, image 2 de 3 Garmin GPS V Front Plate Replacement: étape 5, image 3 de 3
    • Locate the ribbon connector on the logic board.
    • With the spudger, gently apply pressure to both sides of the brown connector lock until it pushes out.
    • With the spudger, gently work the ribbon cable out of the connector until it is free.
  6. Garmin GPS V Front Plate Replacement: étape 6, image 1 de 2 Garmin GPS V Front Plate Replacement: étape 6, image 2 de 2
    • With the spudger, gently pry out the logic board.
    • Be careful to not disconnect the brown antenna wire as you remove the logic board.
  7. Garmin GPS V Front Plate Replacement: étape 7, image 1 de 1
    • Locate the brown wire connection on the logic board.
    • Carefully apply heat with the soldering iron while gently pulling on the brown wire.
    • It may take some time to heat the flux up before the wire can be pulled out.
    • Pull brown wire free of the logic board.
  8. Garmin GPS V Front Plate Replacement, Button Pad: étape 8, image 1 de 3 Garmin GPS V Front Plate Replacement, Button Pad: étape 8, image 2 de 3 Garmin GPS V Front Plate Replacement, Button Pad: étape 8, image 3 de 3
    • Gently pry the button pad off of the front plate.
  9. Garmin GPS V Front Plate Replacement, Display: étape 9, image 1 de 3 Garmin GPS V Front Plate Replacement, Display: étape 9, image 2 de 3 Garmin GPS V Front Plate Replacement, Display: étape 9, image 3 de 3
    • Orient the front plate of the device so the display board is facing up.
    • With the spudger, gently work your way around the display assembly.
    • NOTE: The display assembly is composed of three parts and is glued to the case. Be careful to not separate it when prying it out.
    • Pry the display free of the front plate.
  10. Garmin GPS V Front Plate Replacement, Front Plate: étape 10, image 1 de 1
    • With the display removed, the front case of the Garmin GPS can be replaced.
Connor
Membre depuis le 01/23/12
194 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 3-25, Amido Winter 2012 Membre de l'équipe Cal Poly, Team 3-25, Amido Winter 2012
CPSU-AMIDO-W12S3G25
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 12
Total : 885
