Aller au contenu principal
Garmin GPSmap 60CSx Battery Terminal Replacement
Ce dont vous avez besoin
  1. Garmin GPSmap 60CSx Battery Terminal Replacement, Back Cover and AA Batteries: étape 1, image 1 de 1
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
  2. Garmin GPSmap 60CSx Battery Terminal Replacement: étape 2, image 1 de 1
    • Lift battery release up to remove battery cover.
  3. Garmin GPSmap 60CSx Battery Terminal Replacement: étape 3, image 1 de 2 Garmin GPSmap 60CSx Battery Terminal Replacement: étape 3, image 2 de 2
    • Pull AA batteries out.
  4. Garmin GPSmap 60CSx Battery Terminal Replacement, Battery Terminals: étape 4, image 1 de 1
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
  5. Garmin GPSmap 60CSx Battery Terminal Replacement: étape 5, image 1 de 2 Garmin GPSmap 60CSx Battery Terminal Replacement: étape 5, image 2 de 2
    • Place spudger behind the lower right battery terminal.
    • Push spudger behind the battery terminal to pop it out of place.
    • Now do the same on the bottom left side.
  6. Garmin GPSmap 60CSx Battery Terminal Replacement: étape 6, image 1 de 2 Garmin GPSmap 60CSx Battery Terminal Replacement: étape 6, image 2 de 2
    • Grab the now loose battery terminals and pull them from the GPSMap 60CSx.
  7. Garmin GPSmap 60CSx Battery Terminal Replacement: étape 7, image 1 de 2 Garmin GPSmap 60CSx Battery Terminal Replacement: étape 7, image 2 de 2
    • Flip the back panel over to expose the backs of the top battery terminals.
    • Use a metal spudger to remove the glue that covers them.
  8. Garmin GPSmap 60CSx Battery Terminal Replacement: étape 8, image 1 de 2 Garmin GPSmap 60CSx Battery Terminal Replacement: étape 8, image 2 de 2
    • Flip the back panel back over to view the battery compartment.
    • Place the spudger behind one of the top remaining battery terminals.
    • Push the spudger down and pop the battery terminal out of place.
    • Repeat with the remaining battery terminal.
Thomas Humphrey
Membre depuis le 04/05/18
540 Réputation
4 tutoriels rédigés
9 commentaires
What did you use to replace the contacts?
Austin Chopra - Réponse
Where can I buy replacement terminals?
Mitch - Réponse
Mitch, Garmin just told me they do no sell replacement terminals for this 60CSx. Were you able to find any?
Ernie Sammons -
Where can I find replacement battery terminals for a
Garmin 60CS4?
Sonny Pierce - Réponse
Where can I find replacement battery terminals for a Garmin Map76CS?
Paul - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 127
Total : 8,921
