Introduction
In this guide the repairer replaces the speaker of the device by disassembling the device further to expose the motherboard and speaker.
Prerequisite Guide:
Disassembling Garmin Nuvi 370 Into Core Components
Tools Used:
  • Fine Point Tweezers
  • Spudger
Estimated Duration: 10 minutes
Pièces
Aucune pièce nécessaire.
After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
  • After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
Ajouter un commentaire
Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch. Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch. Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
  • Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
The motherboard will now freely separate from the back casing; lay it flat next to the housing. The motherboard will now freely separate from the back casing; lay it flat next to the housing.
  • The motherboard will now freely separate from the back casing; lay it flat next to the housing.
Detach blue speaker cable from motherboard. Battery cable is detached in this picture, and it is not required to do so to install a new speaker. Battery cable is detached in this picture, and it is not required to do so to install a new speaker.
  • Detach blue speaker cable from motherboard.
    • Battery cable is detached in this picture, and it is not required to do so to install a new speaker.
Detach speaker from casing and insert new, functional speaker. Battery is removed in the picture and is not required for the installation of a new speaker.
  • Detach speaker from casing and insert new, functional speaker.
    • Battery is removed in the picture and is not required for the installation of a new speaker.
Matt West
Membre depuis le 18/04/2013
22 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 13-65, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 13-65, Johann Spring 2013
CPSU-JOHANN-S13S13G65
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 243
