Aller au contenu principal
Garmin Nuvi 2589LMT Battery Replacement
Ce dont vous avez besoin
  1. Garmin Nuvi 2589LMT Battery Replacement, Back Panel Assembly: étape 1, image 1 de 1
    • Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
  2. Garmin Nuvi 2589LMT Battery Replacement: étape 2, image 1 de 2 Garmin Nuvi 2589LMT Battery Replacement: étape 2, image 2 de 2
    • Using the plastic opening tools, pry the shorter sides of the device apart.
    • Once a gap has formed at the top of the device, insert the opening tool into the gap and slide it along the top of the device. Repeat for the bottom edge of the device to separate the LCD screen from the back.
    • Do not disconnect or tear the ribbon wiring, located at the bottom of the motherboard, when removing the back of the device.
  3. Garmin Nuvi 2589LMT Battery Replacement, Battery: étape 3, image 1 de 1
    • Using the angled tweezers, grip the red, black, and green wires connecting the battery to the motherboard, then gently lift away from the motherboard.
  4. Garmin Nuvi 2589LMT Battery Replacement: étape 4, image 1 de 1
    • The battery is held in place by adhesive tape on the underside of the battery.
    • Use the opening tools to gently pry underneath the battery and lift upwards to remove the battery.
3 autres ont terminé cette réparation.
Adam Ferraro
Membre depuis le 10/04/16
920 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team 1-2, Nance Fall 2016 Membre de l'équipe USF Tampa, Team 1-2, Nance Fall 2016
USFT-NANCE-F16S1G2
4 membres
8 tutoriels rédigés
3 commentaires
Where can I buy this battery
Stan Levin
stan levin - Réponse
where can I buy this battery
When pulling off the wires, the plug on the motherboard was coming off. How can I fix it again ?
Hans-Joachim Böhnke - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 30
Total : 4,961
