Aller au contenu principal
Garmin Nuvi 260W Circuit Board Replacement
Ce dont vous avez besoin
  1. Garmin Nuvi 260W Circuit Board Replacement, Circuit Board: étape 1, image 1 de 1
    • Carefully remove model/serial number sticker.
  2. Garmin Nuvi 260W Circuit Board Replacement: étape 2, image 1 de 1
    • Remove two 4mm T5 Torx screws located under the sticker.
  3. Garmin Nuvi 260W Circuit Board Replacement: étape 3, image 1 de 2 Garmin Nuvi 260W Circuit Board Replacement: étape 3, image 2 de 2
    • Once screws are removed, use the plastic opening tool to carefully separate the body from the screen encasing.
  4. Garmin Nuvi 260W Circuit Board Replacement: étape 4, image 1 de 1
    • Once the body of the nüvi is separated, carefully flip the tabs on the motherboard that secure the ribbon cable to the motherboard and disconnect.
  5. Garmin Nuvi 260W Circuit Board Replacement: étape 5, image 1 de 1
    • Once the body of the nüvi is separated and the ribbon cable is disconnected, remove the three 1.6mm Phillips #0 screws.
  6. Garmin Nuvi 260W Circuit Board Replacement: étape 6, image 1 de 1
    • Carefully disconnect the two cables connecting the battery to the motherboard and remove motherboard.
Hunter Johnson
Membre depuis le 03/27/18
327 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S3-G5, Harley Spring 2018 Membre de l'équipe IUPUI, Team S3-G5, Harley Spring 2018
IUPUI-HARLEY-S18S3G5
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 426
