Introduction
For this guide you will be opening the device, but it is fairly simple. Before you begin disassembling the device, be sure the power is off.
Pièces
Aucune pièce nécessaire.
Wedge a plastic opening tool in between the outer frame and the rear panel assembly. Pry the outer frame off the perimeter of the rear panel assembly.
  • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
  • Pry the outer frame off the perimeter of the rear panel assembly.
  • The cover will easily pop off.
Ajouter un commentaire
Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly. Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
  • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
  • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
  • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
Gently pull the battery cable connector from its socket on the motherboard.
  • Gently pull the battery cable connector from its socket on the motherboard.
  • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
Remove the two Phillips #00 screws securing the motherboard to the front case assembly.
  • Remove the two Phillips #00 screws securing the motherboard to the front case assembly.
Slightly lift the motherboard upwards to reveal the LCD assembly.
  • Slightly lift the motherboard upwards to reveal the LCD assembly.
  • Do not remove the motherboard yet, as it is stil attached to the LCD.
Use the edge of a plastic opening tool to flip up the retaining flap on the LCD ribbon cable ZIF socket (highlighted in red, located on the left side.)
  • Use the edge of a plastic opening tool to flip up the retaining flap on the LCD ribbon cable ZIF socket (highlighted in red, located on the left side.)
  • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  • Use the plastic opening tool to pull the LCD ribbon cable out of its socket.
  • Disconnect the right connector using the edge of a plastic opening tool.
Arturo Barajas
Membre depuis le 18/01/2012
11 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 11-19, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 11-19, Maness Winter 2012
CPSU-MANESS-W12S11G19
4 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 1,343
